Go Back   Pelican Parts Forums > Porsche Forums > Porsche 996/997/991 Forum
Leak? 09 997.2 rt ft wheel?
I found “stuff,” something sorta dried black liquid on my wheel. Washed and waxed it off, drove 25 miles and found more, again on the wheel. What is this?
Old 08-20-2018, 04:30 AM
Administrator
Dmitry at Pelican Parts's Avatar
Hello and welcome to the forum! Are you able to post a photo of it? Can you trace where it's coming from?
Old 08-23-2018, 11:58 AM
I cant tell where it’s coming from.
Old 08-24-2018, 04:23 AM
What could be the possible sources?
Old 08-24-2018, 04:36 AM
If you have non OEM rotors with uncoated cooling vents between the braking surfaces, they will rust and sling rusty water everywhere. Your rotors look like you are due for brake work, maybe the pads are near the end of their life causing for dusting & possible rotor damage. Once disassembled solution may be obvious.
Old 09-08-2018, 12:56 PM
Just saw that you have a 997.2 so I assume you have oe rotors or track the 997.2 If you are under warranty I would take it for service asap.
Old 09-08-2018, 01:15 PM
Thanks all for your help and support. Took it to European Performance in St. Petersburg, FL, where Alex checked the wheel, disassembled the wheel and removed the calipers, basically took it down to the spindle and could not find a source for the dark liquid appearing on the wheel. (Nope, never tracked it.) It remains a mystery wrapped in an enigma!
Old 09-27-2018, 05:23 PM
