Go Back   Pelican Parts Forums > Porsche Forums > Porsche 996/997/991 Forum
Willing to learn how.
crosson9's Avatar
Send a message via AIM to crosson9
Sunroofs Are For The Birds.....
I initially thought I had clogged sunroof drains that were causing a small leak. The issue is actually bigger than that and has nothing to do with the drains. There is hinged part of the sunroof frame that has a weather strip attached to it that aids in drainage. Unfortunately for me the one on my car has become misshaped and allows water to leak into the car. Has anyone else experienced this and what's the best way to find this part without buying a whole new frame?
Thanks in advance,
T.J.
Old 09-18-2018, 12:24 PM
Uncertifiable!!!
Uwon's Avatar
What year? Can you ID it on the PET? I don’t recognize that part.
Johan
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, A4 Quattro, the RST hot rod-http://forums.pelicanparts.com/porsche-911-technical-forum/748639-evolution-carrera-rst.html
Old 09-19-2018, 07:06 AM
crosson9's Avatar
It's an '03 and I believe that it is a part of the sunroof frame that's why it doesn't have a part number in the diagram. I'm just hoping someone else on here has seen or had the same issue.
Old 09-19-2018, 01:39 PM
unindicted co-conspirator
looneybin's Avatar
maybe take a piece of small diameter rubber hose, slit it on one side and slip it over the metal flange
might be a good temp fix until you can source the proper part
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control
'86 944 - Wilks PP2, strut brace, harness bar, M030 sway bars, 200# springs, koni adj, throttle cam, K&N filters, momo wheel & shift knob - faster in the twisties than a mustang
Old 09-28-2018, 11:53 AM
Tags
porsche 996 , sunroof
