Go Back   Pelican Parts Forums > Porsche Forums > Porsche 996/997/991 Forum
Should I buy 2003 996?
I have a chance to buy a 2003 996 cab (with hard top) with 27k miles, std, 2 owners for 21 k. Car has two very small door dent but otherwise is very clean shift fine. No smoke no chatter or ticking when started cold. Top in great shape. IMS has not been done. Pulled the oil filter and no signs of failure. The first owner (13 years) put around 1200 miles per year but the Porsche dealer only change the oil every 2 years. The second owner put around 5k per year and changed the oil about the same. Car was always garaged. Don’t have detailed records only car fax. I know it should be done every year. Should I take a chance with no detailed records?
Old 01-02-2019, 06:43 PM
PCA7GGR's Avatar
Ppi
Sergio
PCA - 35yrs / Ex-RGruppe #197
'04 GT3 Halloween/SF Giants car
'11 E550 Coupe (Königstiger)
Old 01-02-2019, 08:04 PM
Had Ppi done checked codes cam angle and over revs. All seems OK question is would sitting and lack of oil change cause long term damage that will show up later?
Old 01-03-2019, 04:43 AM
Behind the Sun
Possible. It is the general knowledge. Use this to your advantage
Take 3k off negotiated price for IMS work and clutch
Old 01-03-2019, 10:59 AM
Too late PPI showed silver shavings in oil filter. Second one that I've look at so far with the same thing. Thinking of going to a 09+ Boxster S PDK wanted a 911
Old 01-11-2019, 12:02 PM
