Go Back   Pelican Parts Forums > Porsche Forums > Porsche 996/997/991 Forum
Brake fluid change
2005 Porsche 996 c4s
Can you change brake fluid the old fashion way of pumping the pedal and holding it down when you have psm OR DO YOU NEED THE pst2 in order to activate the valves during brake bleeding
Old 10-10-2019, 10:33 AM
Administrator
Dmitry at Pelican Parts's Avatar
For cars with traction control or Porsche Stability Management (PSM), you need to use the Porsche System Tester 2 (PST2) in order to activate the valves in the hydraulic unit during the bleeding process. If your car has a "PSM off" switch on the dashboard, then you will need to go to a shop that has a PST2 so that the brake system can be bled properly.
Old 10-10-2019, 11:04 AM
Brake fluid change
A lot of people on forums say you can bleed it old fashion way but it does change the fluid in the pump.Some people even say some garages don't bleed it the proper way
Old 10-10-2019, 11:35 AM
Administrator
I based my response on Wayne's diy tech article - other members will likely chime in with their expertise as well.
Link: https://www.pelicanparts.com/techarticles/Porsche-996-997-Carrera/48-BRAKES-Bleeding_Brakes/48-BRAKES-Bleeding_Brakes.htm
Old 10-10-2019, 11:40 AM
Brake fluid change
Thanks for coming back so quick.
JFP in PA
JFP in PA
Moderators
585
Posted November 2, 2013
On 11/2/2013 at 1:38 PM, Bk4205 said:
Ok, I have read that some Porsche owners that own 996's with the PSM option have done brake flushing without out the use of a PC based diagnostic tool to activate the electronics in the braking system, some state it is also necessary to use the diagnostic software?
I have ordered the Durametric cable for my 2002 996 Carrera along with a refurbished laptop off of EBay for the purpose of working on the car and was told by the folks at Durametric that this is one of the functions that the program can provide. What is actually being turned ON during the flushing event using a software diagnostic tool such as Durametric?
Brad
As Loren noted, cycling the ABS/ PSM systems is only required if you have replaced major components in the ABS or PSM system, or gotten air into them; otherwise it is not necessary. Even dealerships do not cycle these systems during a flush unless specifically needed.
Old 10-10-2019, 11:49 AM
Administrator
JFP in PA
JFP in PA
Moderators
585
Brad
Thanks for the note David - good to know
Old 10-10-2019, 11:51 AM
Brake fluid change
Your welcome
Be nice to if other people have changed there fluid without PST2 tester
Old 10-10-2019, 12:01 PM
unindicted co-conspirator
looneybin's Avatar
What about using a Motive pressure bleeder?
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control
'86 944 - Wilks PP2, strut brace, harness bar, M030 sway bars, 200# springs, koni adj, throttle cam, K&N filters, momo wheel & shift knob - faster in the twisties than a mustang
Old 10-19-2019, 08:50 AM
Brake fluid change
Just purchased a Sealey VS820 Brake and Clutch Bleeding System.
Will this do the job,
o you still need pst2 in order to activate the valves during brake bleeding
Old 10-19-2019, 10:03 AM
