Go Back   Pelican Parts Forums > Porsche Forums > Porsche 996/997/991 Forum
Torque on Water Pump Bolts
Is 7 ft-lbs really enough torque for the water pump bolts on my 996?
Old 10-22-2019, 03:42 AM
Spec is 7.5 so I go 8 with no problems
Old 10-22-2019, 10:46 AM
Just saw you other post on the same subject. If using anti-seize 7 is plenty.
Old 10-22-2019, 10:49 AM
BigTim
A 1/4 inch drive, inch lbs torque wrench will be better suited to access the bolts and torque to
95 inch lbs.
HTH
Tim
Old 10-31-2019, 02:49 PM
NutmegCarrera's Avatar
Location: Plymouth Wi. - Spitting distance from Road America
FWIW -
I just did the water pump (and thermostat, and timing belt, etc....) in my daughter’s Subaru last weekend.
This guy has M6 screws holding the water pump on. I never even had the chance to feel one of them snug up before it pulled the original threads out of the block.
So, yeah. Follow the torque spec.
*In my case, I was able to reach with a drill / tap and insert a heli-coil. But I wasn’t happy about needing to do it. My guess is that the block casting was not so great in that one specific area.
Old 11-01-2019, 09:49 AM
Jeff Alton's Avatar
Torque is 10nm approx 7.5 lb/ft. No antisieze or other compound is required or recommended.
Cheers
jeff@turn3autosport.com
997 S 4.0, Boxster 2.7, Boxster S race car, 958 Cayenne TT, VW GTI 2.1 TSI, Mini Cooper S JCW, Cannondale Supersix EVO SRAM RED E-tap, Cannondale Slice SRAM RED E-tap
Old 11-07-2019, 10:15 PM
JFP in PA's Avatar
Cheers
Au contraire......we find fasteners associated with coolant, like the water pump or thermostat housing, can benefit from the use of anti seize compound. These fasteners suffer more from dissimilar metal and water corrosion that nearly any other in the engine, and being snapped off when being removed as the result. A little ant seize never hurts.
Accrochez-vous bien de vos rÍves..........."
Old 11-08-2019, 07:18 AM
Jeff Alton's Avatar
Do as you wish. These fasteners are not exposed to coolant when installed. Never seen one that would not come out easily on these engines, but perhaps it happens.
Old 11-08-2019, 12:38 PM
