Go Back   Pelican Parts Forums > Porsche Forums > Porsche 996/997/991 Forum
DBF DBF is offline
Electrical Connector Problem with Photos
I have an electrical connector with a loose wire. I can't figure out how to remove the pin so I can crimp or solder the wire. The female pin is loose in the connector (I can wiggle it with a pin tool), but I don't see any place to use a pin removal tool to remove the pin. Any advice?
Old 01-15-2020, 07:52 PM
Uncertifiable!!!
Uwon's Avatar
What year?
Looks aftermarket. Looks like there are three sections- outer, inner, and black retaining cover. I would guess that the black retaining cover will slide out if you relieve the locking fingers at each end. Then it will all come apart.
Good luck.
Johan
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, A4 Quattro, the RST hot rod-http://forums.pelicanparts.com/porsche-911-technical-forum/748639-evolution-carrera-rst.html
Old 01-16-2020, 04:11 AM
DBF DBF is offline
This is the connector for the right rear window on my 99 cabrio. The black retainer holds a small rubber plug that helps secure the pin. However, even with the retainer off and the rubber plug removed, the pin is still not sliding out of the connector.
Old 01-16-2020, 06:55 AM
JFP in PA's Avatar
Needs a special tool that slides over the connector terminal and depresses a small tang, the terminal will pop right out. SIR and OTC both make the tool.
Accrochez-vous bien de vos rÍves..........."
Old 01-16-2020, 09:12 AM
Correct. There is a round tube that slides over the round connector pins from the front. Then you pull the connector out from the back (after you remove the black locking plate). It rarely pops right out, but it does come out,
Porsche 2005 GT3, 2006 997S
Exotic: Ferrari F348TB Factory Challenge, Ferrari 328 GTS
Disposable Car: BMW 530xiT, Audi A3S
Two-wheel art: Ducati 907IE Ö for now
Old 01-16-2020, 10:42 AM
DBF DBF is offline
Thanks. Picked up the tool from Advanced Auto Parts.
Old 01-18-2020, 08:24 PM
