BobnJoz
What doe these plug into?
What "do" these plug into. This is on a '13 991 front right inner fender area. Two wiring plugs but I don't know where they go. I just got the car with front damage and there were some missing bits. I got all the new parts, put them in and have two extra plugs with nothing for them to plug into. Headlight is plugged in, cooling fan plugged in, fuel door actuator is plugged in. Smaller plug is in the fuel door area. And the larger plug is in the same harness as the cooling fan. What else could be in there? Thanks for any suggestions.
BobnJoz
Figured it out, (in case anyone in the future needs to know but not likely). The larger plug is for turn signal and parking assist harness for front bumper. (right side only). When I got the car, it had a miss match front bumper without parking assist. But, the bumper grills had the sensors. The harness on the drivers side had plugs for 4 things. I thought, 2 sensors and two turn signals. But, the original bumper had locations for 4 sensors. Which means, it needed more wires from the passenger side, and a proper bumper which I happen to have an extra. Problem solved.
