wider tires up front of a 996 C4 2001 Aerokit
How will my performance be affected with 2 sizes large front tires? if at all. 245/35/18
on 8" wheels ( instead of the stock size 225/40) and paired with 295/30/18 on 10" wheels, Is it worth the try? Any one tried this? No track just agressive/spirited tweesty roads driving !! ![]() ![]()
84 911 Carrera SOLD not forgotten 01 911 C4 factory Aerokit ![]() 76 914 rust bucket SOLD !! 03 Boxster S sold 98 944 S2 G Red,sold 04 FRC red Vette |
Any one ?? have any thoughts on this ?
It will improve turn-in and cornering grip, reduce understeer, and reduce top speed slightly. We have experimented with front tire sizes on a 986 (same front end) anywhere from 205-285. I ran in Time Trials with 255 up front for 2 years.
2009 Cayman PDK With a few tweaks 2021 Cayman GTS 4.0L 2021 Macan (dog hauler) |
Thank you for your input that helps a lot
I wouldn't go bigger than 235 F & 285 R just buy the best performance tire available. |
Michelins wear out much too fast, and diameter is a factor , in order to keep it sort of even I have come up with General ultra perf summer 245/35 and 295/30 seem to be close
Science is NOT optional
What front shocks were you running? Stock perches and springs seem a little wide, might rub. Coilovers would make it easier.
PCA member since 1993 |
