-   Porsche 996/997/991 Forum (http://forums.pelicanparts.com/porsche-996-997-991-forum/)
-   -   996 turbo mezger engine build specs? (http://forums.pelicanparts.com/porsche-996-997-991-forum/1063099-996-turbo-mezger-engine-build-specs.html)
racer86 06-03-2020 10:36 AM
Hi All,
Hope you're well. I'm taking on the rebuild of a 996 Turbo engine (with my professional engine builder friend...i'm not a wizard!), but I've drawn a blank on the build specs....Looks like if you take your motor to Porsche they give you a new long block, so even in the 2000 page technical document we have, it doesn't have specs...
Specifically we're looking for:
- What are the running clearances on the valves – exh / in
- What is the piston to bore clearance?
- What are the specs for the cam / crank / IMS journals, running clearances and thrusts?
- What are follower wear limits / running clearances?
- What are the oil pump clearances?
I've done a forum search and can't find anything either....
Thanks in advance for any help you can give or anyone who'd know we can get in touch with.
Rob.
BYprodriver 06-03-2020 10:55 AM
If you are going to increase the boost pressure you will need to deviate from Porsche clearance spec's
JFP in PA 06-04-2020 06:55 AM
Originally Posted by racer86 (Post 10890214)
Hi All,
Rob.
Porsche never published this information.
