2001 996 Turbo Spoiler Hydraulic Fluid
The pump motor comes on with the dash switch or at 75 mph, the Spoiler Failure indicator comes on, but motor sounds as if there's no hydraulic fluid. Motor will only shut off when key turned off. No apparent fluid leak. How does one check the hydraulic fluid in the rear spoiler mechanism and what hydraulic fluid should be used to refill?
Thanks... |
It uses Pentosin PS fluid. Mine went out twice before I gave up: https://rennkit.com/our-story/
Thread Tools | |
Rate This Thread | |
