Banned
2.5 engine
Hi every body has any body doped a 3.2 Engine and Box in to a 2.5 ? yes i am mad would love to put a 996 TT in it
The Boxster 2.5, made in 98 and 99, can accept a 996 3.4 motor directly. The 2000 Boxster 3.2 has a different DME version and is not a direct swap. The early 996 3.4 motors, up to and including the MY 2001 will fit.
Tony G 2000 Boxster S |
We have a customer that did exactly that: Put a Mezger engine out of a wrecked turbo car into a 986. Let me begin by telling you the guy who did the swap owns an automotive fabrication business with all the welding, CNC, milling, and other type equipment you could imagine, so he could make literally anything he needed; and he completed a beautiful installation, which had some shortcomings:
Be careful what you wish for, the owner of this monster could make anything he needed for the car, but ended up pulling the Mezger out and selling it, and installing the engine that was originally in the car.
Accrochez-vous bien de vos rêves..........." Last edited by JFP in PA; 08-11-2024 at 08:12 AM.. |
It's a 914 ...
A later Boxster/Cayman trans might address the driveline weakness. I believe the transmissions from the early cars were known to be weak.
Banned
Well a friend told me 3.2 is common ground but will need some updates to the ecu and fuel system and wiring. If you want power just LS swap your boxster its cheaper then putting a 996 turbo in its about a 20k difference for less hp if you go the 996 tur o route thats 40k for the 996 turbo engine swap vs 17-22k for an ls swap that gives you 700hp your call if you have the money!
Accrochez-vous bien de vos rêves..........." |
