Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 996/997/991 Forum
EEES's Avatar
Passenger door won't open from outside of the car
My door opens and closes fine from the inside. The whole locking system works great but the door latch will not release from the outside. The lever just moves freely. This is when the passenger door is unlocked, and I can pull the outside handle and the window will drop down. It was giving me a hard time the last few months. The handle would only pull out halfway and then the door would just barely release and open up. Then one day, it just completely stopped opening from the outside, and now the handle moves freely, but the door can only be opened from the inside.
Any ideas? Is it the outer door handle pull lever trigger? Does anybody have a tutorial? I have all the tools to take this apart, but I want to make sure I have the right part.
Thank you in advance,
Ian
1999 C-2 Cab
Old 03-29-2010, 07:26 AM
What was your solution?
Seems I have the same issue with my door. Won't open from the outside but it does trigger the window. Did you arrive at a solution?
Thanks in advance!!
Old 12-12-2011, 03:27 PM
Check this thread out: Door Lock will not Lock or Unlock from outside? - RennTech.org Forums
In my case, tiny circlip 11 dropped out and pin 10 fell out, releasing the entire handle mechanism. Your case may be different, but this may be a good starting point.
Good luck.
2003 Porsche 996 C2 coupe, Speed Yellow
2011 BMW 328xi, Crimson Red
Old 12-12-2011, 05:23 PM
Good luck.
This was the same issue with my door handle. A trip to ace hardware and a $.30 yes..thirty cent...split rivet did the trick. I did not have to take the airbag out, but I did disconnect the battery to keep the auto window from going down each time the lock twisted. In all, a 3 hr job and lots of patience...probably 1.5 hrs if I have to do it again....if you have fat fingers...phone a friend because it is tight.
Old 01-14-2012, 02:20 PM
EEES's Avatar
Thank you for all of your replies. This forum is amazing!
1999 C-2 Cab
Old 01-15-2012, 10:06 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
