996 Repair Estimate
Ok just lookin for a ballbark estimate on the following:
1999 996 with 80K miles on the clock. #1 cylinder is leaking coolant after dash warning light came on. Engine was shut down and no internal failures apparent as there is no oil/water transfer evident...(no milkshake). If you check the heads, replace headgaskets, do the rear main seal and install LN Bearing fix what should this all cost? I'm sure there must be a few folks who can chime in!
08 Cayenne V6 89 911 Targa Carrera 3.2 75 914-6 Conversion |
The only part I can speak to is the LN bearing replacement. I got a quote of $3000 from a reputable Porsche indy for that and to change the RMS while he was at it. That was on a 2002 996 a couple of years ago. Good luck.
Mike |
Accrochez-vous bien de vos rêves..........." |
Yep, most likely a cracked head. There are places repairing them.
Kurt |
External leak? Can you get a Pic? There are other components that can leak:
AOS is one
2013 991.1 Carrera S Cab 2004 996 Turbo CAB X50 sold 2003 996 cab 6 speed Sold 1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold DE instructor since 1985 |
Cracked head or crack cylinder? I though that the early 996 crack cylinders.
Robert
1985 Euro Red Carrera Coupe."SOLD",1985 White Targa Carrera. "SOLD",1977 Yellow 930. "SOLD",1991 Black 964 C4. "SOLD",2002 Silver 996 C4 Cab "SOLD", 2001 Polar Silver 996 twin Turbo |
Speculation is useless. Get it to someone you trust. Tear it down and figure it out. Then you will know what is right for you.
996 engine
Thanks for all the replies guys.
