Go Back   Pelican Parts Forums > Porsche Forums > Porsche 996/997/991 Forum
Weekend Mechanic
vulcan300's Avatar
IMS Bearing Upgrade Question
There are three chain tensioners on the 996 engine (Main Tensioner, 1-3 Cylinder Bank, 4-6 Cylinder Bank). Wayne's article only mentions loosening/removing the main tensioner and the 1-3 tensioner. Is the 4-6 tensioner (located under the AC compressor) not a concern?
86 911 Carrera Targa
Old 06-27-2011, 10:30 AM
When I did my IMSR, I loosened all 3, but I have read many times that the 4-6 is not necessary to loosen.
Rick
99 996C4
06 525XI
87 944S - Sold
77 924 - Sold
Old 06-28-2011, 05:00 AM
Weekend Mechanic
vulcan300's Avatar
Thanks for the answer Rick. Did you remove the tensioners completely or did you just loosen them a bit? Did you use the set screws to secure the IMS sprocket or did you just lock the cams? Or both?
Old 06-28-2011, 01:40 PM
I just loosened IMS, 1-3, and 4-6. I just made sure that I didn't move the cams in the process and confirmed they didn't jump during the procedure.
Rick
99 996C4
06 525XI
87 944S - Sold
77 924 - Sold
Old 07-01-2011, 04:37 PM
FPB111's Avatar
pin the crank at TDC before you start and it should be OK. Fancy tool can be replaced by 5/16 metal rod
2004 996 Turbo CAB X50
2003 996 cab 6 speed Sold
1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold
DE instructor since 1985
Frank
Old 07-02-2011, 06:24 PM
