Go Back   Pelican Parts Forums > Porsche Forums > Porsche 996/997/991 Forum
ktn ktn is offline
Replace Brake - Need advise
I am about to replace my brake on 996. How to I know when to replace the rotor? what tools to I need to measure if my rotor still good or need replacemnet.
Old 12-03-2011, 06:32 AM
JFP in PA's Avatar
You need a decent micrometer to measure the rotor thickness.
Accrochez-vous bien de vos rêves..........."
Old 12-03-2011, 06:44 AM
You need a dial caliper or 1" micrometer. Be sure to measure in the center avoiding any ridges that have developed at the edges. Th minimum thickness is stamped into the perimeter of the disc. Sand the edge with a 3M pad to find it. Be prepared to replace them as they are generally considered a wear item these days. However, they can be freshened by turning if they are not too far gone.
Old 12-03-2011, 06:47 AM
ktn ktn is offline
Thank you for the info.
Old 12-09-2011, 08:31 AM
one of gods prototypes
bell's Avatar
be aware if you have drilled or slotted rotors they cannot be resurfaced......
Brought to you by Carl's Jr.
Old 12-09-2011, 12:29 PM
ktn ktn is offline
Brake replacement
Bell,
Thanks for the info I will keep that in mind.
Old 12-11-2011, 02:08 PM
