Soaked Carpets
Very frustrated with 2006 Carrera Coupe. Many, many problems but will save the inventory of historic and current issues for another time; if ever.
Most current pressing item is the soaking of passenger carpet, both front and rear when car experiences rain, either driven or parked. Also happens when driven through car wash. No water on drivers side. In reviewing other posts I suspect there are clogged drains. Can anyone assist with the location of the drains and how I can go about clearing? Also, are there other culprits that can cause the soaking. Car has spent approx 50% of its life outdoors, but not near trees. Live in Florida, so you might imagine this problem seriously restricts the amount of driving I can enjoy. Any guidance is very much appreciated. |
Has the door panel ever been off? If so check the waterproof membrane between the panel and door frame for gaps/rips/missing sealant around the edge, etc. Also check the drains in the bottom of the door.
2013 991.1 Carrera S Cab 2004 996 Turbo CAB X50 sold 2003 996 cab 6 speed Sold 1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold DE instructor since 1985 |
As far as I know, door panels have not been removed. Appreciate the suggestion.
I had the same problem with my 996. The solution was to clean the two cowl drains, one on each side of the battery box. The left drain is hidden under the brake master cylinder, and a bit of a pain to access. The right drain is directly accessible. After removing years of matted crap, I no longer have wet carpets.
Dave |
Thanks. I'll try the cowl drains and see if that's it.
I had wet carpet too and it was not clogged drains. Where the drain tubes attaches to the sunroof tracks, there are plastic adapters that are sealed with caulking. Mine were dried out and leaking at that junction running down the headliner into the carpet. I removed and used a RTV to reseal. No issues since then.
Rick 99 996C4 06 525XI 87 944S - Sold 77 924 - Sold |
