Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 996/997/991 Forum
Porsche Crest Dot 5 Brake Fluid or Not?
2006 997 C4S 45,000 miles. Is Dot 5 brake fluid (the blue stuff) bad for the seals in this car? Have heard conflicting stories. I change the fluid at the end of summer and in the spring after sitting all winter.
Mordaunt P. Brabner
2006 997 C4S
Old 04-18-2012, 06:28 PM
JFP in PA's Avatar
Do not use DOT 5 brake fluid, these cars were not designed to use it. Use DOT 4 such as ATE Blue or ATE 200.
Accrochez-vous bien de vos rÍves..........."
Old 04-19-2012, 03:09 AM
Well said,
Thanks for the info. Is there a source document I can reference?
Platt
Ne rÍvez pas trop petit sinon vous y arriver!
Mordaunt P. Brabner
2006 997 C4S
Old 04-19-2012, 03:48 AM
This has always been confusing. Dot 5 (purple color) is silicone and does not mix with the other brake fluids. Dot 5.1 is the same as Dot 200 or Dot 4 Super and is all the same.
Old 04-19-2012, 06:17 AM
JFP in PA's Avatar
Originally Posted by 997 C4S View Post
Well said,
Platt
Probably the best source is the OEM service manuals (online only via subscription), which spec Dot 4 fluids. DOT 4 cars are not necessarily DOT 5 compatible. We have had a couple customer's try the DOT 5 silicone based fluid, which resulted in multiple seal failures and a very some large repair bills.
Old 04-19-2012, 10:25 AM
JFP in PA's Avatar
And don't forget the SL 6 low viscosity fluids for cars with the ESP stability management electronic braking systems............
Old 04-19-2012, 10:31 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
