Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 996/997/991 Forum
JW Apostate
trekkor's Avatar
'99 996 suspension rattle
Buddy of mine just dropped off a high mileage car for me to work on.
He says it rattles when going over bumps.
I haven't driven it yet, but suspect the top shock mounts.
Is this typical for these cars?
KT
'74 914-6 2.6 SS #746
'01 Boxster
'73 914
Old 05-04-2012, 05:02 PM
one of gods prototypes
bell's Avatar
most common things I see are front lower control arms (the ball joint......easier to swap whole arm).
also sway bar links go bad, and have seen the upper shock bearings......
be careful, allot of times the rattle/squeek will disappear as soon as you jack it up and unload the suspension....only to have it return later.
Brought to you by Carl's Jr.
Old 05-05-2012, 08:42 AM
JW Apostate
trekkor's Avatar
I drove it last night. Nothing alerts me.
He describes the noise as being as distracting as having a four year old in the back seat.
So far I'm not hearing this.
I'll need to drive the car all day, up and down the coast, to figure it out!
( His idea. I have the car on loan 'til next week when we swap for his other car for service )
KT
'01 Boxster
'73 914
Old 05-05-2012, 08:52 AM
bell's Avatar
I've seen the sway bar links seem ok but rattle like babies when the load changes.....
also seen the upper shock mounting creak and tick, I've gone as far as greasing the metal to metal contact points.....
something else to check......the dme and other modules is mounted to an aluminum tray behind the rear seat, I've heard these make strange decieving noises also when they aren't properly secured....
Old 05-05-2012, 10:24 AM
JW Apostate
trekkor's Avatar
All good to know.
Thanks for the ideas.
Getting ready to go!
KT
'01 Boxster
'73 914
Old 05-05-2012, 10:29 AM
JW Apostate
trekkor's Avatar
What a fun day trip.
Napa to Santa Rosa, to Jenner, to Ft Ross, to Bodega Bay, to Petaluma and back to Napa.
160 miles~
It seems the noises are all related to ill fitting interior trim, rattling windows and wind noise from worn seals. Car is solid.
I'll peek under the car, but I don't think there are any problems
Handles very well, has good acceleration and is, I'll just say, very peppy.
Fun day!
KT
'01 Boxster
'73 914
Old 05-05-2012, 05:48 PM
dewolf's Avatar
I had a rattle in the back of the Boxster I just bought and got under to discover that I could wobble the sway bar around. The D bushes were shot. Replaced them and no more rattle.
How do find the water cooled car over your air-cooled? I know they are chalk and cheese. You car being a track car.
How many miles on that 996?
In Heaven… the mechanics are German, the chefs are French, the police are British, the lovers are Italian and everything is organized by the Swiss.
In Hell…the mechanics are French, the police are German, the chefs are British, the lovers are Swiss and everything is organized by the Italians.
Old 05-05-2012, 09:59 PM
JW Apostate
trekkor's Avatar
I'll lift up the car this week and look for anything loose.
We'll see.
KT
'01 Boxster
'73 914
Old 05-05-2012, 10:02 PM
If the car has aftermarket lowering springs, that might be your issue. I had a 2001 and a 2002 both with lowering springs and the darned coils would hit each other causing weird rattles. Fixed it by wrapping a piece of hose around the coils... Took forever to trace...
Good luck,
Chris
Old 05-14-2012, 11:32 AM
I had a similar thing in my 1999 996, I replaced the sway bar links (just did this on my 1999 Ford Explorer too!), AND I tightened down the spare tire, which I think was the real noise maker! Knocks and noises are gone!
Old 05-26-2012, 06:13 AM
JW Apostate
trekkor's Avatar
Rode in the car on the track.
Very clunky in the turns with slicks on. Not with street tires.
The rear sway drop links are not free moving and are not indexed properly.
The owner had the windshield replaced, and the 'mechanic' on site tried to sell him on replacing the rear wheel bearing for $600, because it clunked as the car starts moving forward or backward.
Also on uneven transitions, like driveways.
Wheel is solid feeling on the hub and there is no grumble or hum when moving. ( first sign of bad bearing )
Guy was a hack.
KT
'01 Boxster
'73 914
Old 05-26-2012, 08:39 AM
Rapewta's Avatar
I can't help with an answer to the rattle but I too have developed a "clunking" sound now coming from under the car.
It is a 99 C2 6 sp coupe with 82K. About 1K miles back I started noticing the clunking sound whenever I would go over any rough spot in the road. It is annoying and I can't find it.
The motor mounts are less than a year old and are not the problem. I will probably take it in and have it diagnosed. The mechanic is good and he tells me what the problem is and so far I have been able to repair the car myself.
I just did the water pump when it started rattling.
BTW... we just got back from Napa after cruising up 29 to Calistoga and going on a balloon ride from Yountville to Napa, landing in a field near the college.
What a beautiful area to live in.
Old 05-30-2012, 07:52 AM
