Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 996/997/991 Forum
Question 996 leak-down test
I'm trying to do a leak-down test on my 996. On my '71S it was easy to find TDC for each cyl by following the valve adj procedure, rotating the crank& pulley 120d. I see what may be a TDC mark on the 996 pulley but ?? I know about holding a stick in cyl, etc but that seems the hard way esp alone without a long third arm... and an eye on a stalk. Also, how does one remove the rear valence? Where are all the screws? Are there any hidden? It is prob easier with the cats & cans off, huh? tnx, jvm
JVictor
Old 05-18-2012, 03:59 PM
TDC on the pulley is thru the pear shaped hole into the case hole at !0:00- 11:00 with a 5/16" allen wrench if you don't have the tool in the pic. This lines up the pulley mark & TDC arrow on the case @ 2:00 on the case for TDC cyl.1 & cyl. 4
Old 05-18-2012, 05:50 PM
Hey OC, Thanks so much! I'm in to it again tomorrow. jvm
JVictor
Old 05-18-2012, 09:14 PM
one of gods prototypes
bell's Avatar
also......leave the exhaust on....just jack up the rear to a good height..
first wiggle the rubber cover up of the connector for the coils (will make plugging the coils back in easier...trust me)....then unplug coils....
find a small ratchet with a good 5mm allen and pull coils....
when pulling the plugs I like to use 2 short extensions as it gets tight when you pull them out with the mufflers in place....
follow the previous post to tdc each cylinder.....
Brought to you by Carl's Jr.
Old 05-19-2012, 04:48 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
