Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 996/997/991 Forum
Current 2012 Porsche 996 recommende oil list
Any body have a current Porsche recommended oil list? Its oil change time of the year for me. I think last year i put the M1 0W-40 in her. I was reading that some folks were using the rotella 5W-40T now? Thanks for any info
This is for a 2001 996 tip that i dont track. i use as every day transportation in southern Ca.
Old 07-18-2012, 08:11 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Mobil 1 is fine. More importantly is how often you change the oil. Don't do the 15,000 mile oil changes with any Porsche that has the IMS issues. Change the oil more frequently, like 4-5k max or at least once a year if you drive less miles than that annually.
The Rotella oil by Shell is good for the flat tappet rockers for the older air cooled 911's but Brad Penn is better. Besides, I believe that Rotella is not synthetic like M1.
Tony G.
2006 Cayman S
1986 911 Carrera track car...gone but still loved!
Remember Warren Hall. Contact me for your Warren 'Early S Man' Hall memorial decals.
Old 07-18-2012, 10:48 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
JFP in PA's Avatar
The Shell Rotella T5 line is a blend, the T6 line is a full synthetic. Neither have ACEA ratings, which is a more critical issue.
Accrochez-vous bien de vos rÍves..........."
Old 07-18-2012, 01:00 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
FPB111's Avatar
Latest? List.
http://www.pedrosgarage.com/Site_3/Porsche-Approved_Oils.html
Motul 8100 5-40 has been recomended by LN Engineering since they started offering the IMSB repair kit. Motul 8100 X-Cess 5w40 Porsche Approved Full Syn (5 Litres). Get a magnetic drain plug while you are there.
Oils: What motor oil should I use? Which oil is best for my Porsche or aircooled engine?
Turner Motor sport has had good prices on it.
MOTUL 8100 5W-40 X-cess Synthetic Engine Oil - 5 liter jug 2 $44.95 $89.90
2004 996 Turbo CAB X50
2003 996 cab 6 speed Sold
1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold
DE instructor since 1985
Frank
Old 07-18-2012, 01:46 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
I challenge you to check out Amsoil. They have a European formula 5-30 and 5-40 that will compare to and or exceed the performance any of the oils mentioned. They have zinc fortified formulas as well.
the prices will compare as well. Go to amsoil .com and check out the different products if you decide to try it get 20% off by using referral code 5026324.
Old 07-20-2012, 02:01 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Amsoil 5-40 for me use the 10-30 in the vette also
Old 08-14-2012, 10:25 PM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Amsoil 15-50 for me, stritcly a race car though
Old 08-16-2012, 01:17 PM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
Luxter's Avatar
Hi JFP.
I believe T6 carries ACEA E9 cert, doesn't it?
On another note, Amsoil AMO 10W-40 appears to be a good fit for 996/7 engines with increased ZDDP levels and Sulfated ash compared to Euro blend.
Has anybody tried AMO in water cooled yet? Any comments?
Cheers,
=L=
Old 08-17-2012, 12:11 PM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
JFP in PA's Avatar
Last tech sheet we saw for the T6 did not list any ACEA ratings, but they may have gotten them after it was released. In any case, E9 is for long drain cycle commercial diesel engines with particulate filters. What you should be looking for is ACEA A3, B3, B4 ratings.
As Amsoil is not a signatory to the ACEA Technical Consortium Agreement (a requirement to participate in ACEA’s mandatory independent lab testing protocols), none of their products would have an ACEA rating of any type.
Old 08-17-2012, 01:23 PM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
Joe Gibbs DT40 or Motul Xcess 8100 5W40
Old 08-17-2012, 01:31 PM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
Rapewta's Avatar
I have 84,000 miles on my 996. Triple digit temp location. All original. Mobil 1 0W-40 is all I have used. OK so far. Every 6k miles. I cut open the filter and have not seen anything but nice looking oil.
It's a 100 bucks a pop if you do it yourself. I know Porsche says to change it at higher intervals but I still change it about once a year, which is about 6k miles.
I don't know where the oil goes but I keep it topped off and that is about 1 quart between oil changes. They use oil and it doesn't come out of the exhaust pipes.
Old 08-17-2012, 04:34 PM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
Thanks for the Info Rapewta and other posts. I did go with the mobil 1 0-40 found it at wally mart for 6.5 a Qt. easy enough change.
Old 08-20-2012, 07:25 AM
  Pelican Parts Technical Article Directory    Reply With Quote #12 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
