FS: 3.6 Eng/Accessories 2003 67k miles
I'm parting out a 2003 3.6 engine from a C4S 996 with a IMS failure. I'm in the process of a LS3 install. P. M. Let me know what you need
Thanks, Mike ![]() ![]() |
Those bearings just need a little lube to hold them in place while you repack them......
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo 2001 996 GT2 1999 Spec Boxster, 1996 993 Cabriolet 1992 964 Cabirolet, 1975 911 RSR Replica Race Car |
weetart
Price of entire engine? Thanks
Got the engine torn down, it's in excellent shape, no scoring in cylinders/pistons. No valve contact with pistons. It's one of the best 67k miles wear engines I've seen.
Needs IMS shaft and bearings and bearing holder, no case damage in this area. Chain tensioner on crank to IMS broke, others barely worn. BIG PROBLEM is that the dealers mechanic broke the top rt Transmission mount ear off the engine case. Not sure IF this can be welded and retaped? Listed on E-bay ![]() Last edited by Fierofly; 02-21-2013 at 01:30 AM.. |
