intermix problem with 996
hello , i need some advice, i have 1999 996, few days ago i lost coolant in system, as i later fined out it got into oil, i bring car to Porsche center they think problem is oil cooling radiator, did anybody had such problem? do you know what it can be if not this radiator? can it be oil/air separator? please advice
Intermix issues caused by the oil cooler are not that uncommon. If it is the oil cooler, they can pull it and pressure test it to confirm.
Accrochez-vous bien de vos rêves..........." |
one of gods prototypes
Its a good place to start.....if its not that it could be major...unfortunately.
Brought to you by Carl's Jr. |
sorry to hear about your problem.
I wonder if I got lucky when I noticed a coolant leak. http://forums.pelicanparts.com/porsche-996-997-forum/716942-coolant-top-right-cyl-bank.html?highlight=oil%2Fwater What would have to be done to clean the water out of the engine? Let us know what you find. Good Luck, I hope the tab isn't to high |
read this thread on how Darn55 fixed his.
Intermix/Cracked head repair - Rennlist Discussion Forums
2013 991.1 Carrera S Cab 2004 996 Turbo CAB X50 sold 2003 996 cab 6 speed Sold 1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold DE instructor since 1985 |
Today I got new radiator, lets see how it will be, i cross my fingers.
Keep us posted.
let say so they are still testing, now it seams that we are losing Oil
, oil level went down. is it normal? what it cam mean??
just to update, IT IS NOT RADIATOR, now we will disassemble Engine, will start with head as I was advised.
From a 3.6 -- Not sure how easy this would be to see from a boroscope -- but certainly worth the try.
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo 2001 996 GT2 1999 Spec Boxster, 1996 993 Cabriolet 1992 964 Cabirolet, 1975 911 RSR Replica Race Car |
see post #6 for a common type of crack in the head. 1 - 3 side most often. These can be repaired. see post #5
I am Back, and again same problem, crack in the head, on first cylinder. exactly same as shown above, today I am taking it for welding lets see.
