sprint booster problem after installation on 996 mk2
So I finally installed my Sprint Booster. Did not go easy as it can be read on an article here. Finally got it installed but I was not to happy with the installation given that the cable connecting to the engine management system did not provide for any slack, resulting in a very tight coupling and cable being stressed.
Finally tested and experience is really nice. However after some kilometers I got ABS failure alarm and PCM disabled. Reading about these messages, often they are related to the brake light switch. Eventually I uninstalled and alarms were gone. Also the tight coupling puts tension on the connector/cable which I think is not good in the long run because vibrations eventually can cause damage. Any help on this one? |
Yeah, don't bother to install it.
| All times are GMT -8. The time now is 02:33 AM. |
