Go Back   Pelican Parts Forums > Porsche Forums > Porsche 996/997/991 Forum
Seeeu911's Avatar
ODB code P0348
OBD code P0348 the info from my basic reader displays "camshaft position sensor A - Bank 2 Circuit high input"
Is a 2003 C4S 75k miles. I've a Durametric on order. Any thoughts ?
"And there's no cure like travel
to help you unravel
the worries of living today.
when the poor brain is cracking
there's nothing like packing
a suitcase ..(or getting in the Porsche) and sailing away " Cole Porter, anything Goes"
Old 11-07-2013, 03:57 PM
Codes starting with 0 are all generic codes required by law. This code says your cam position sensor impedance shows high values. It means your sensor is bad, or has a broken wire in the connector. The fix is to replace it. Clear the code, and drive.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 11-07-2013, 08:35 PM
Seeeu911's Avatar
Good info, thanks !
to help you unravel
Old 11-08-2013, 05:44 AM
JFP in PA's Avatar
P0348 is telling you that the signal on sensor #2 is permanently high; most likely a failing cam position sensor. Fun to get at, but not a real problem to change out.
Accrochez-vous bien de vos rêves..........."
Old 11-08-2013, 05:57 AM
