change front drop links
When the front drop link is removed (997) will the wheel carrier slide down the shock?
If so, how do you prevent this possibility? If it does slide down somewhat, how difficult is it to put it back in the proper position? |
Just put something under it to support it (jack) or tie it to the spring.
| All times are GMT -8. The time now is 12:46 AM. |
