-   Porsche 996/997/991 Forum (http://forums.pelicanparts.com/porsche-996-997-991-forum/)
-   -   OBD error codes, advice please (http://forums.pelicanparts.com/porsche-996-997-991-forum/826633-obd-error-codes-advice-please.html)
mhariush 08-22-2014 10:42 PM
I got a check engine light yesterday on my 1999 C2 and as it turns out, my durametric (clone) cable just gives me a red light so I can't connect it. But I picked up a code reader from Harbor Freight today.
I get the following codes:
P0102
P0446
Any idea on where to start? Anyone experienced these? The car starts and runs like it always did
http://forums.pelicanparts.com/uploa...1408772199.jpg
http://forums.pelicanparts.com/uploa...1408772206.jpg
http://forums.pelicanparts.com/uploa...1408772223.jpg
http://forums.pelicanparts.com/uploa...1408772230.jpg
http://forums.pelicanparts.com/uploa...1408772236.jpg
leave car or drive car while figuring this out?
JFP in PA 08-23-2014 08:30 AM
Originally Posted by mhariush (Post 8227135)
I got a check engine light yesterday and as it turns out, my durametric (clone) cable just gives me a red light so I can't connect it. But I picked up a code reader from Harbor Freight today.
P0102
P0446
First of all, when asking this type of question, always include the year and model of the car as it can make a difference in which is the correct answer.
Assuming it is a 1999 car:
P0102 - Mass airflow sensor below lower limit; likely faults: break in the wiring, short to ground.
P0446 - EVAP canister shut off valve below limit; likely faults: purge air line blocked, flow blockage in the EVAP canister
mhariush 08-23-2014 11:43 AM
Hi, thanks. Yes, 1999 C2.
I see the codes, and I found what the OBD manual says about it. Is there any thing I should check before that? Is this commonly caused by something?
Someone also asked me if I had occasional trouble starting the car, and yes I do. If takes a few extra cranks to start it, I think. And a few times I tried starting it but it didn't, I had to wait a minute and try again.
Here's the OBD manual steps. Just start going through them then? I don't have the Special Tool, can I get around not using it?
P0102
http://cimg5.ibsrv.net/gimg/rennlist...62e7d8cc40.jpg
http://cimg6.ibsrv.net/gimg/rennlist...417633ea3d.jpg
http://cimg7.ibsrv.net/gimg/rennlist...f8d5025519.jpg
http://cimg8.ibsrv.net/gimg/rennlist...7ac7244ac0.jpg
P0446
http://cimg9.ibsrv.net/gimg/rennlist...39cb095c96.jpg
http://cimg0.ibsrv.net/gimg/rennlist...859ffe11fd.jpg
http://cimg1.ibsrv.net/gimg/rennlist...aa5361afe2.jpg
JFP in PA 08-23-2014 01:46 PM
You can get around using the "special tool", which is a Porsche specific pin out box, but it is going to be a lot more time consuming as you would need a digital multimeter and the car's wiring diagrams to test the circuits.
mhariush 08-24-2014 03:27 PM
I cleaned the MAF. The air filter and inside of the air box was fairly "dirty" for a filter I replaced in July.
Cleared the codes. Let's see how that goes.
Live OBD data.
http://forums.pelicanparts.com/uploa...1408919101.jpg
