I have 06 c2 is it possible to change the plugs without the removal of the headers and muffler? thanks
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
Yes definitely, requires a bit more patience and a good selection of different length extensions with wobble capability to get the job done on the passenger side of the car especially for cyls 4 and 5. I say go for it. I like to use a 3 inch wobbly extension, a stubby 1 inch extension, a spark plug socket and a 12" long ratchet with wobbly head. Using the separate extensions will allow you to remove the stubby once you get the plug far enough out to grab the 3" extension...otherwise it will hang up on the muffler bracket...Removing the rear wheels also really helps provide access.
- Casey |
And it really helps if the car is on a lift...
These tools help make it somewhat easier.
kd service kit 41740 Sears.com Kobalt 24 piece metric tool kit. Shop Kobalt Metric Mechanic's Tool Set (24-Piece) at Lowes.com [http://forums.pelicanparts.com/uploa...1433956852.jpg http://forums.pelicanparts.com/uploa...1433956863.jpg http://forums.pelicanparts.com/uploa...1433956880.jpg |
| All times are GMT -8. The time now is 04:22 AM. |
