 I have a 2006 c2 that has fresh oil change with filter, Mobil 1  0/40# and I get 5 bar oil pressure after warm up still get 5 bar at 4000 rpm and at idle get 2+bar. I I think it is supposed to be 3.5 bar at 3000 rpm. Where should I look to correct the problem? gauge or sensor or both?
	__________________ This post was auto-generated based upon a question asked on our tech article page here:  |
 3.5 bar at 3000 RPM seems low to me.  I am not aware of a spec for oil pressure at 3000 RPM.  If it was low I'd recommend checking the oil pressure relief valve but your values seem to be about normal.
	- Casey  |
 The only certain way to confirm oil pressure is with a good mechanical gauge . Your pressure seems normal to me but if it is way off the first suspect is usually the sending unit
| All times are GMT -8. The time now is 07:00 PM. |
