-   Porsche 996/997/991 Forum (http://forums.pelicanparts.com/porsche-996-997-991-forum/)
-   -   Replaced battery but now the top won't move, and the "top" light in dash above speedometer doesn't come on when key is in proper position. Windows still work and the fuse appears to be ok position #1. What do you suggest? (http://forums.pelicanparts.com/porsche-996-997-991-forum/872995-replaced-battery-but-now-top-wont-move-top-light-dash-above-speedometer-doesnt-come-when-key-proper-position-windows-still-work-fuse-appears-ok-position-1-what-do-you-suggest.html)
Michelle (guest) 07-01-2015 10:27 AM
I need your help! Battery failed last night on my Porchea 911 Cab while top was down; got jump start and made it home. However, when I was putting the top down the battery failed again when top was about 4 inches from closing/locking. Replaced battery but now the top won't move, and the "top" light in dash above speedometer doesn't come on when key is in proper position. Windows still work and the fuse appears to be ok position #1. What do you suggest? Can I get a manual to figure out how to put top up or down manually to get it somewhere to fix? I need your help!!! Thank you!
This post was auto-generated based upon a question asked on our tech article page here:
Casey at Pelican Parts 07-01-2015 10:27 AM
Yes the Bentley Manual does have the emergency closing procedure. Go to pelicanparts.com and search for: PEL-P905 to find the manual. Definitely worth the money it has TONS of good information for you. I would suggest checking the parking brake switch though. When you lift the parking brake lever does the "park brake" light come on in the dash?
- Casey
