-   Porsche 996/997/991 Forum (http://forums.pelicanparts.com/porsche-996-997-991-forum/)
-   -   driving my 2000 996, temp 90C, but temp light flashes, cannot hear the radiator fans. Car starts and drives normally, fuses okay, rad level okay but after reaching operating temp 90C, light flashing....could both front rad relays both faulty? (http://forums.pelicanparts.com/porsche-996-997-991-forum/873130-driving-my-2000-996-temp-90c-but-temp-light-flashes-cannot-hear-radiator-fans-car-starts-drives-normally-fuses-okay-rad-level-okay-but-after-reaching-operating-temp-90c-light-flashing-could-both-front-rad-relays-both-faulty.html)
Navidad (guest) 07-02-2015 11:14 AM
This post was auto-generated based upon a question asked on our tech article page here:
Casey at Pelican Parts 07-02-2015 11:14 AM
Check the coolant level. If the coolant level is OK the engine compartment purge fan or engine compartment temp sensor could have a problem.
- Casey
Mitch Leland 07-08-2015 09:49 PM
As you already know the dash light will blink for one of three conditions.
1. Coolant is low in the expansion tank, could be a bad sensor at the tank...
2. Engine room fan not working
3. Engine room temps too high
Some where there's a breakdown on which item is not working by determining how the dash light flashes. Maybe the owner's manual, Bentley's, or?
Have you canceled/erased the fault light with an OBDII reader. You can buy them at Auto Zone, a good thing to have on board your car. I got a middle priced one for $90.00.
