Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 996/997/991 Forum
Porsche Crest Horn Not Sounding
2000 996 Coupe has a horn that beeps perfectly when I use my key to alarm the car. However, when I push on the airbag the horn does not sound. Even when pushing hard, the air bag does not budge forward or give in anyway to indicate that it is being compressed. Any thoughts would be helpful.
Old 08-14-2016, 05:48 PM
FPB111's Avatar
Two different horns. The alarm horn is under the cowl by the battery. The driving horns are under the front bumper cover. This is a video showing changing horns on a Boxster. The 996 has two screws behind the marker light. One that is easy and one under the wheel well cover.
https://www.youtube.com/watch?v=_pxqCU5i5nM
996 bumper cover removal
https://www.youtube.com/watch?v=Um-h2aUJHY4
2004 996 Turbo CAB X50
2003 996 cab 6 speed Sold
1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold
DE instructor since 1985
Frank
Old 08-17-2016, 08:56 AM
wolds's Avatar
Horn relay? Fuse for horn? track these down and check them
Lorraine 83 SC CAB RoW
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 08-24-2016, 08:33 AM
Probably need new horns. Pretty common problem. Once you get the bumper off, check voltage at the connectors to the horns and if you have voltage replace the horns...
Here is a link to the horn page...
Old 08-31-2016, 08:03 AM
Tags
996 , horn
