Go Back   Pelican Parts Forums > Porsche Forums > Porsche 996/997/991 Forum
Door glass auto drop down
My 2003 996 drivers side window auto drops correctly upon pulling the inside or outside door handle then it instantly pops back up while door is open upon release of door handle. Drivers side only, no battery issues. I'm thinking micro switch. Any suggestions for further diagnosis?
Thanks in advance, Paul
Old 10-26-2016, 06:13 AM
Administrator
Dmitry at Pelican Parts's Avatar
Hey Paul,
Check out this tech article on the 996 window regular and motor; hopefully it'll help you troubleshoot and fix the issue. Let us know how it goes. Best of luck!
Porsche 911 Carrera Window Regulator and Motor Replacement - 996 (1998-2005) - 997 (2005-2012) - Pelican Parts Technical Article
-Dmitry
Old 10-26-2016, 01:23 PM
dgmark's Avatar
Your problem is in the door open closed switch in the latch, It thinks the door is still closed. Your dome lights are probably immediately going off when the latch is released also. You have to replace the latch assembly as I do not think the switch is supplied separately.
30 Year ASE Master Certified Technician
1986 911
Old 10-27-2016, 07:56 AM
dgmark, I think you are correct and yes, the dome lights go out when latch is released and the door is still open.
Thanks, Paul
Old 12-04-2016, 10:58 AM
Door latch assy
Well, needless to say I haven't fixed this issue yet. Is this 8N1-837-015-C-OEM
door lock mechanism the part you are referring too?
https://www.pelicanparts.com/cgi-bin/ksearch/PEL_search_2016.cgi?command=DWsearch&description=door+latch
Thanks, Paul
Old 02-25-2018, 09:32 AM
Banned
Thanks, Paul
That is where the switch is located. 8N1837015C
Old 02-25-2018, 11:33 PM
Old 03-02-2018, 03:28 AM
