Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 996/997/991 Forum
Originally Posted by rufrob View Post
Yup. The overflow hose popped off. Looks like I put the clip on upside down. Didn't think it would have made such a difference. I yanked on it hard after reattaching and it didn't come out. So figures crossed.
Rob,dont yank to hard on your hose.Haha
Sent from my SM-N910T using Tapatalk
Old 01-25-2017, 03:51 PM
rufrob's Avatar
My sister told me the same thing.
Btw, I though it was still leaking because of a coolant smell from the new rad and the level kept falling. Turned out the rad and AC condenser was full of coolant and the system was almost empty. It took about 10liters.
Never give up
Old 01-26-2017, 12:08 PM
Bad LT
Uncle's Avatar
LOL I just started reading your thread as an ex 930 (see sig) now AC cobra owner looking to get back into a P car. Seems we all share some common taste as I’ve also been tempered by a mates E55 AMG.
3.3 with ported heads,964 cams,3.2 manifold, Haltech EFI,WTA intercooler,BW366,Fabspeed headers,TIAL gate and ARP studs other than that it's completly stock.
Old 02-03-2017, 12:49 AM
rufrob's Avatar
Still getting used to the 996. I'm saving money for the seemingly inevitable remaining radiators, tires, coolant hose pinning, water pump and rear spoiler.
I have done some search but couldn't find if anyone has grounded their radiators to slow or stop corrosion?
Has anyone tried those GT2 rear decks from EBay?
The E55 has impressed me with its outstanding reliability, versatility, and truly impressive performance. I know the newer AMG models are faster but definitely not cheaper to buy and maintain.
Never give up
Old 02-03-2017, 03:50 PM
rufrob's Avatar
Pulled door panel today to see what's what with the window regulator. Found about 10mm play in the cable. I put a mini hose clamp at the regulator end behind the speaker. Done. Now it drops properly.
Never give up
Old 02-04-2017, 11:53 PM
rufrob's Avatar
After "passing" a Prius vigorously , coolant leak again!! This time the upper rad hose. I'm really getting good at this. Now I repair without removing the front bumper. This time drained the system from the front rads and engine drains, and raised the back when refilling. Let's see how long this repair lasts.
Never give up
Old 02-12-2017, 12:02 PM
techweenie's Avatar
I have heard that the radiators are a "maintenance item" at $1500/set you'd think they'd last as well as 944 radiators. But no.
I wanted to add: once you have it sorted, drive it hard and you will notice the car "wakes up." It has 'learning ability' in the ECU and if the PO drove too gently, the car learned to underperform.
techweenie | techweenie.com
Marketing Consultant (expensive!)
2004 996 Turbo Cab, triple black | (all out of longhoods)
2018 Chevy Volt dd/parts fetcher
Old 02-16-2017, 02:18 PM
rufrob's Avatar
Does anyone know how to fit a rear GT2 spoiler from a C4 to a Turbo?
Never give up
Old 02-22-2017, 05:00 AM
rufrob's Avatar
The TT measures 70cm between mounts the C4 measures 90cm.
Never give up
Old 02-22-2017, 05:10 AM
rufrob's Avatar
New kix!!
Never give up
Old 03-16-2017, 12:45 PM
rufrob's Avatar
Never give up
Old 03-16-2017, 12:47 PM
rufrob's Avatar
Hi y'all. Getting a clunking, something loose noise at the front end over small bumps like pothole covers and pebbles and cracks. Brakes not steering don't affect it. I checked that all the front gear is secured.
Any suggestions?
Never give up
Old 07-23-2017, 01:25 PM
rufrob's Avatar
The only thing I found was one of the coolant pipe clamps was loose. Let's hope that was it.
Btw from the look of the the strut should be able to lowered into the hub carrier. Has anyone done this?
Never give up
Old 07-28-2017, 04:33 PM
rufrob's Avatar
Anyone know a way to fix this?
Didnít notice the right mirror was folded slightly hence I miss calculated and hit the right rear bumper.
Never give up
Old 10-16-2017, 01:10 PM
A body shop should be able to repair that with a plastic welder.
Bryan O.
77 930
08 Boxster
14 535i M Sport
Old 10-18-2017, 02:12 AM
rufrob's Avatar
I wonder how much it would cost stateside. It cost about $200 here to get it fixed.
Never give up
Old 10-19-2017, 05:24 AM
rufrob's Avatar
Finally got around to doing to front strut bearings, bump stops and boots. They were stupid easy to do. With an impact gun I undid the strut top nut, popped out and wound down the spring, so low tension, pulled the piston down, swapped the parts. Total time 1hour both sides. So far, no more noise from front suspension. Then the headlights donít come on.
Never give up
Old 10-19-2017, 05:28 AM
Did that include paint repair? For example, I had my 987 front bumper repaired and repainted and it was $1200. Same car had someone reverse into it and dented the same bumper. Couldn't be repaired this time and the cost for a new bumper, paint and a right Xenon headlight was just under $5k.
Bryan O.
77 930
08 Boxster
14 535i M Sport
Old 10-20-2017, 01:22 AM
rufrob's Avatar
Wow. Guess I got a good deal. Yes it included paint. I did the bumper re/re. Checked the fuses and relays and ordered a headlight switch. Here it cost $250.
Never give up
Old 10-20-2017, 04:31 PM
rufrob's Avatar
Update on suspension knocking noise. Took the car on 2 long trips on the highway and country roads. First trip revived the knocking noise. Upon inspection I found the main pinch bolt 16mm for the left strut/knuckle was loose. Tighten it up. Noise gone. Yesterday back to the same area, the noise returned again but this time only on really rough country roads. On the highway and normal city roads no noise. Any ideas? Remember I changed both front strut bearings. But now the right one creaks like a old door hinge or bed spring when wet.
Never give up
Old 01-20-2018, 07:29 PM
