Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 996/997/991 Forum
996 Coilover upgrade
Recently my 996 standard suspension/ struts have become crappy, I've been told by my mechanic it needs to be changed. I want to upgrade to coilovers.
I have found a set of lightly used Cross JIC 996 2004 turbo coilovers. I am wondering will these physically fit on my:
996 2002 C2
-What is the difference between all these coilovers besides the weight springs?
-Would they physically fit my car?
-If i were to put turbo coilovers on a C2 would it be too hard of a ride.
Thanks in advance.
Cheers
Old 12-15-2016, 04:06 PM
I am almost certain turbo struts will not fit. The turbos are AWD and this complicates the suspension swap. I'm not 100% for the 2002 996 but the first run of 3.4 996's would not swap without a LOT of other parts. Ultimately costs more than a PSS9 set up.
An alternative is a new set of bilstein sports and lowering springs. Coil overs are nice if you're doing a lot of DE's. If you want a better suspension, a mild upgrade is the sports. It'll give you about a 1.2" lowering as well.
Tony G.
2006 Cayman S
1986 911 Carrera track car...gone but still loved!
Remember Warren Hall. Contact me for your Warren 'Early S Man' Hall memorial decals.
Old 12-16-2016, 11:03 AM
Thanks for your reply tony!
Hmm that's interesting.... Is it the diameter of the coilovers or the sleeve for the struts different?
Would anyone have measurements that i could compare?
Old 12-16-2016, 11:59 AM
Not sure what the difference is. The TT and the C4 are wide body cars, so there may be some dimension differences there as well as the AWD. You might want to check with a shop like EBS in Reno for a better answer. Could also try Rennlist and search around there.
Tony G.
2006 Cayman S
Old 12-16-2016, 12:30 PM
cdrik915's Avatar
I don't know your budget , but if you plan to replace your coilovers for betters , you should think to Ohlins Road & track.
Adjustables , 30 clics , very light , and not expensive viewing the result .
With mines , i've just discovered another car , nothing less.
That cost 1700 euros , without cost of shipping .
Notice the spring diameter , comparing originals ones.
LIGHTER = FASTER !!!
Old 12-21-2016, 10:24 AM
David 23's Avatar
Curious what spring rate you have, and your thoughts about the performance.
1979 911SC Backdate Project
2004 996 40th Anniversary Edition
1955 Austin Healey 100/4 Original owner/family.
1971 Morris Cooper S Aussie Build, fully modified 1330cc
Previously owned several 911 models since 1975.
Old 01-10-2017, 06:50 AM
Administrator
Luccia at Pelican Parts's Avatar
+ on Ohlins. Great coil over. We also have a bunch of other great options for the 996 here: PelicanParts.com - Porsche 996 (1999-2005) - Suspension & Steering. Let me know if you have any questions.
Old 01-12-2017, 08:53 AM
Tags
996 , jic , porsche , strut , suspension
