Go Back   Pelican Parts Forums > Porsche Forums > Porsche 996/997/991 Forum
ronvanr (guest)
Guest
Posts: n/a
997 brake line question
2005 997 C2, when you remove the brake line from the caliper, what do you cover the end of the brake line with so it does not leak? Tape, if so does it matter what kind? If not tape, do you have a recommendation?
Thanks!
This post was auto-generated based upon a question asked on our tech article page here: Porsche 911 Carrera Brake Caliper Rebuild - 996 (1998-2005) - 997 (2005-2012) - Pelican Parts Technical Article
Old 02-13-2017, 11:19 AM
A 3mm vacuum rubber cap also works well.
- Casey
