Go Back   Pelican Parts Forums > Porsche Forums > Porsche 996/997/991 Forum
Aly (guest)
Guest
Posts: n/a
I don't believe it is an instrument panel problem because I get an error code when I read the codes, I think it was P0641 or something like that that has a phrase "Alternator L-Terminal".
I am thinking that maybe I have the 2008 alternator which puts out more or less voltage than the 2006 alternator. If I had the 2006 alternator on the 2008 engine in the 2006 car, I can't see why it would matter.
Do you know what the difference is in the alternators between 2006 and 2007/2008? They are not the same part number.
Thanks for your reply.
This post was auto-generated based upon a question asked on our tech article page here: Porsche 911 Carrera Alternator Replacement - 996 (1998-2005) - 997 (2005-2012) - Pelican Parts Technical Article
Old 02-16-2017, 10:29 AM
I am not sure the difference, but I believe one is Bosch and the other Valeo?
- Casey
