Go Back   Pelican Parts Forums > Porsche Forums > Porsche 996/997/991 Forum
Juriscon (guest)
Guest
Posts: n/a
I have a 2005 997 with 64,035 miles. It also has 11mm on the body and 10mm from the end of the flexible hose and all around the caliper.
Three nuts were extremely difficult to remove. I used PB and let them soak by wrapping them then applied heat with a MAP torch. The left front on the chassis did not move so I cut the line. It runs a short distance to a monoblock ? and is easy to replace. My flare nut wrench Kobalt did fine on the others.
My advice is if you have a nut that gets damaged, replace it or the line.
This post was auto-generated based upon a question asked on our tech article page here: Porsche 911 Carrera Brake Line Replacement - 996 (1998-2005) - 997 (2005-2012) - Pelican Parts Technical Article
Old 02-24-2017, 12:24 PM
Better to replace the line.
- Casey
