Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 996/997/991 Forum
Battery
I have a friend that has a 2002 996 that needs a battery and wants to replace it with a porsche battery. It has a american battery now . What is the battery that Porsche installed at the factory(the name) so I can buy that battery. Also what would I need to make sure that when I removed the battery to replace it, how would I not lose all the codes on the car .
Old 06-05-2017, 10:31 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
If you want an original style battery go to the dealer.
As far as codes go, you may need to plug a booster into the cigarette lighter as a back feed into the system while the battery is replaced.
BTW, if you ever need the code, give the dealer the VIN and they should give you the correct code. Do it while you're on the phone, as there may be more that one that was used by the factory.
Tony G.
2006 Cayman S
1986 911 Carrera track car...gone but still loved!
Remember Warren Hall. Contact me for your Warren 'Early S Man' Hall memorial decals.
Old 06-05-2017, 02:08 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Why a Porsche battery? I had an Interstate in my 930 and replaced it 2 month ago with an AGM. That Interstate was 8 years old. Last month I replaced my 4 year old Porsche battery in my 987 with an AGM. My 996tt has an Interstate in it right now and is about 3 years old. When it dies, I'll go with an AGM, too.
Bryan O.
77 930
08 Boxster
14 535i M Sport
Old 06-06-2017, 03:13 AM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Any reasonable battery is fine. Any codes lost will recover after a brief drive.
Do you even know the special codes that go with your car? They are very VIN specific. If they don't recover, let your certified Porsche dealer put them back in for you.
Dan
Old 06-27-2017, 10:48 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
FPB111's Avatar
What year? 2002 on store radio codes in the ecu/dme so unless one changes the radio no codes need to be reloaded. Throttle reset, ignition on 60 seconds no touch pedal, off for 60 seconds done. Window retrain, down hold 15 seconds, up hold same done.
2004 996 Turbo CAB X50
2003 996 cab 6 speed Sold
1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold
DE instructor since 1985
Frank
Old 06-29-2017, 04:57 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
DanielDudley's Avatar
Is this procedure still the same for a 2013 Boxster ? I have a guy telling me that only an authorized Porsche battery can be installed, and that it needs to be ''registered'' to the car or it won't work. I told him it just needed to be back fed, but he says no.
Old 07-14-2017, 02:30 PM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
