Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 996/997/991 Forum
Porsche Crest Connecting the battery while the engine is out of the car
Greetings
My 2002 996 C4 suffered a catastrophic failure (cracked cylinder wall) within last month. I have not decided what to do with it yet, but would like to give it a good wash before putting the car cover on.
My mechanic left the windows and trunk open when he removed the engine. I don't want water getting into the trunk or the cabin, of course.
Is it safe to temporarily connect the battery to get the windows up, close the trunk, wash the car, then re-open the trunk to store the car cleaned?
Thank you
P.S anyone looking to buy an engineless beautiful 2002 996 C4 Cab in Lapiz blue and natural leather interior?
Old 06-28-2017, 01:09 PM
FPB111's Avatar
As long as the positive cable in the engine bay is not touching anything, tape it or slip some rubber hose over it, you should be ok.
Just in case you might want to pull the right headlight and left taillight and pull the emergency release cables out in the open to make sure that you can get the lids open again.
2004 996 Turbo CAB X50
2003 996 cab 6 speed Sold
1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold
DE instructor since 1985
Frank
Old 06-29-2017, 02:12 PM
Thanks, FPB111
I'll remove the headlight/rearlight as you suggested. It's sad to see this car in 'pieces.'
Old 06-29-2017, 02:22 PM
FPB111's Avatar
Not sure how you cracked the head on a 3.6 but if it is like the 3.4 cracks the head can be fixed for around $4k.
One of many
https://rennlist.com/forums/996-forum/503269-intermix-cracked-head-repair.html
Frank
Old 06-29-2017, 02:55 PM
My mistake on the original post, what cracked was a cylinder wall.
Cheers
Old 06-29-2017, 02:59 PM
FPB111's Avatar
I'm sure that by now you have found that can be fixed also. Just more $$.
Frank
Old 07-05-2017, 11:57 AM
Only two options for my case
Thanks FPB111.
Unfortunately the only two choices my mechanic gave me were 1) buy a new engine from porsche, or 2) buy a used engine. Both options are on the expensive side, particularly because I had spent about 10K in 2016 in a lot of preventive work to avoid a catastrophic failure.
Are you aware of other options? I'm open to any options that get my car on the road again at a 'reasonable' cost.
______________
2002 996 C4 Cabrio --currently engineless
1992 Carrera -Sold
1982 911SC Targa -Sold
1977 911 -Sold
Old 07-05-2017, 01:01 PM
FPB111's Avatar
Probably most " reasonable" is a used engine. With that you really don't know what you have. You would want to replace the IMSB, AOS, water pump, low temp thermostat and inspect for scoring before you install it.
Better is using LN Engineering "Nickies"
https://lnengineering.com/products/watercooled-cylinders-pistons.html
Also look into MB Motors
*** *** *** *** *** *** ***MB MOTORSPORTS - Porsche engine repair and maintenance service
Vertex also offers rebuilt engines
it looks like vertex URL is blocked on Pelican?
Frank
Old 07-06-2017, 09:15 AM
FPB111's Avatar
You don't say where you are or who you are using.
As shops get more familiar with these engines more are rebuilding them. There might be one in your area.
Personally I would not leave my Engine with a shop that wasn't going to do something with it now. It will get moved around and libal to start shedding parts. Plus anything loose, bolts, mounts etc. will get separated from the engine and lost. Where is the trans?
Frank
Old 07-06-2017, 09:43 AM
I'm in South Santa Clara county (Gilroy, Ca). And the car is sitting pretty in my garage, with the engine partially uninstalled, and the removed pieces in boxes. Disappointment feeling every time I go into the garage and see it there. It's looking like my 4rth Porsche will be the last Porsche I own.
______________
1992 Carrera -Sold
1977 911 -Sold
Old 07-06-2017, 02:46 PM
FPB111's Avatar
It is good that you have decided to keep it forever.
Try posting on Rennlist asking for help/shop suggestions etc...
https://rennlist.com/forums/996-forum-60/
Frank
Old 07-07-2017, 06:32 AM
