Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 996/997/991 Forum
996 not start. Electric down ..
Not run motor start only
My idea is failure immobilizer !
Old 07-08-2017, 05:14 AM
FPB111's Avatar
Mine is failure battery.
2004 996 Turbo CAB X50
2003 996 cab 6 speed Sold
1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold
DE instructor since 1985
Frank
Old 07-09-2017, 04:13 PM
First step clean battery terminals and cable ends well then retry. You could try a jumper box and see if it will start with that. If so most likely battery or dirty cables.
Old 07-11-2017, 08:43 AM
Ok tanks i have alredy change the battery end cable exsternal it same problem !
No have contact on key out
I change electric contact it is a same. !!
I have start on the motor starter direct end it is ok.
996 run perfect. ! Who is a problem ?
Inviato dal mio HTC One M9 utilizzando Tapatalk
Old 07-16-2017, 06:50 AM
FPB111's Avatar
Check the clutch switch? Jumper across the two wires with a spade connectors jumper.
Check the "Y" cable in the engine compartment. Also check the ground from chassis to engine, right side near rear tire.
Have you checked all fuses?
Frank
Old 07-16-2017, 02:17 PM
Tanks
I have cecked all fuse in pedal zone
Who is the clutch switch ? Zone ?
The cable Y it is ok
Old 07-20-2017, 08:37 PM
FPB111's Avatar
The clutch switch is above your toe when your foot is on the clutch. See fig1
Porsche 911 Carrera Brake Clutch and Cruise Control Switch Replacement - 996 (1998-2005) - 997 (2005-2012) - Pelican Parts Technical Article
Frank
Old 07-21-2017, 06:09 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
