Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 996/997/991 Forum
Engine Swap-Boxster 3.2 into 3.4 1999 996
What does it take to drop a 3.2 Boxster engine, into a 1999 996 that had a 3.4 in it?
1. Do I need to swap wiring harnesses?
2. Will the 1999 ECU recognize the 3.2 without any CEL?
3. Any parts need to be swapped from the 3.4 to 3.2?
4. The 99 is a Tipronic. Does the 3.2 HAVE to be a TIP also, or can it be a manual?
Here is the reason. The 99 just had massive engine failure at 145K on the car. Otherwise, the car is in great shape, Tipronic and all. 3.2 engines are a lot cheaper than 3.4 engines on EBay. I know I will be giving up some HP. That is ok...This is simply a DD car, to and from to work and running around town. I use it to keep from running up the miles up on my 2002 996 Convertible Six speed.
Old 07-13-2017, 08:23 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Administrator
Luccia at Pelican Parts's Avatar
Have you taken a look at our Boxster Engine Swap / Carrera Engine Conversion DIY tech article? Should be somewhat similar... Either way it has a lot of great info so be sure to take a look at it here: Porsche Boxster Engine Conversion Project - 986 / 987 (1997-08) - Pelican Parts Technical Article. We did this to our in-house 986.
Old 07-17-2017, 02:17 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Hi, does anyone know the outcome of boring out a 3.2 S. and fitting 3.6 nickasil liners and pistons
With new steel rods, either standard length or shorter 3.6 items , retaining standard crank ,any info greatly appreciated .thanks
Old 08-16-2017, 05:05 AM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
