Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 996/997/991 Forum
Front license plate bracket
Just purched 2001 996 turbo. My state requires a front license plate. I already have 2 square holes in the bumper. Seems very difficult to access behind the bumper. Do i need to remove the front bumper just to mount a front license plate bracket?? Any feedback will be greatly appreciated
Old 07-13-2017, 04:46 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
FPB111's Avatar
See this thread.
https://rennlist.com/forums/996-turbo-forum/986849-front-plate.html
Also Pelican has all of the parts to mount as stock or the tow hitch mount.
2004 Porsche 911 Turbo Convertible - Exterior Trim - Page 3
Expanding Nut (in Front Bumper Cover) for License Plate Bracket (2 Per Car)
Part #: 999-507-040-40-M100
License Plate Bracket Spacer, Right, Front
Part #: 996-701-802-00-M100
2004 996 Turbo CAB X50
2003 996 cab 6 speed Sold
1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold
DE instructor since 1985
Frank
Old 07-13-2017, 06:45 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Thanks for your reply. I didnt notice a procedure to mount the expanding plugs?? Where do i gain access to the back of the bumper?????
Old 07-13-2017, 08:03 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
In my experience, the expanding nut does not work THAT well--but you just screw it in from the front--no removing of bumper cover. I lost my plate somewhere during a major downpour (hit a puddle) here in CA. I bought a whole new setup and new plates, but the plate can still be pulled off pretty easy. I just keep it in the frunk and hope I don't get a ticket--can't justify $30+ for the bumper plugs though, either--but I hate the front plate.
Old 07-14-2017, 09:37 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Yes i agree, but dont want the hassle of being pulled over. Do you know if i would need spacers to mount the license plate bracket? Thanks for your reply
Old 07-15-2017, 03:41 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
FPB111's Avatar
Look at the pieces listed on the Pelican page.
LOOK AT THIS PAGE ON PELICAN,
http://www.pelicanparts.com/cgi-bin/ksearch/pel_search_2016.cgi?command=show_part_page&please_wait=NG&make=POR&model=927&section=BDYEXT&page=3&bookmark=8&part_number=PEL-996-BRACKET
TWO SPACERS, LEFT AND RIGHT, TWO SQUARE LOCKING NUTS.
ON THIS PAGE LISTED BELOW
LOOK AT THE PAGE REFERENCED ABOVE.
Everything mounts from the front.
My C2 holes were enlarged by a PO so I used these plastic Twist Lock anchors with the stock spacers and plate mount. Never came off.
http://www.homedepot.com/p/E-Z-Ancor-Twist-N-Lock-75-lb-8-x-1-1-4-in-Philips-Zinc-Plated-Nylon-Flat-Head-Drywall-Anchors-with-Screws-4-Pack-11364/100165900
Frank
Old 07-15-2017, 06:07 PM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
PCA7GGR's Avatar
Get a license mount that used the tow hook mount.
Sergio
PCA - 34yrs / Ex-RGruppe #197
'04 GT3 Halloween/SF Giants car
'11 E550 Coupe (Königstiger)
Old 07-15-2017, 06:46 PM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
NY requires it too. I haven't run a front plate for two years. Haven't been stopped yet. I keep the plate in the frunk. If I ever get stopped, will tell officer just had front bumper painted and picked car up at the shop. Going to mount plate when I get home. May not work, but sticking it on the front of the car looks like ass. Worst case, get the bracket that installs in the tow hook adapter.
Old 07-18-2017, 06:14 PM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
I would order a set of bumper plugs in your body color and then pick up a tow hook plate holder. Don't know if Pelican sells them.
Old 07-21-2017, 09:29 AM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
Generally, I am impressed with the engineering thoroughness done by Porsche. The design of the factory front bumper plate holder, however, is a complete failure in my opinion. I bought my 2003 C2 from a previous owner in California where it had no front license plate. When I brought it back to Colorado, I needed to put a front plate on in order not to be harassed for not having one. I bought and installed the OE Porsche front plate mount (using larger screws to better secure it). What a disaster! A simple nudge on it while opening the frunk would cause it to fall off. I have struggled with this for the last 8 years, even trying JB Weld to keep it from falling off.
I looked at getting one of the tow hook systems, but I don't like the off-center look that results. I just installed the Skene Design "no holes" front bracket. Simple, and all seems well now. (https://skenebrackets.com)
2003 Porsche 996 C2 coupe, Speed Yellow
2011 BMW 328xi, Crimson Red
Old 07-31-2017, 12:03 PM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
Thanks for the advise. I dont actually see my car listed on their site? Maybe i will just have to measure the bumper as they suggest, or possibly the 997 turbo might fit?? I will contact them. Thanks again
Old 08-02-2017, 11:51 AM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
88carrera. Would you possibly be so kind to post a pic of your license plate attached, or just the mounting bracket. Did you purchase the short bracket?? Looks very straight forward. Thanks again
Old 08-04-2017, 08:14 AM
  Pelican Parts Technical Article Directory    Reply With Quote #12 (permalink)
JFP in PA's Avatar
There are a couple of companies that make "disappearing" front license plate systems, which retract the plate under the front of the car when you don't need it:
Accrochez-vous bien de vos ręves..........."
Old 08-04-2017, 08:50 AM
  Pelican Parts Technical Article Directory    Reply With Quote #13 (permalink)
Hi Wilbo, Yes, here are a couple of shots of my front mount, one from the side and one from the bottom. I got the "extra short" bracket.
I am happy with this bracket. It has seen 90 mph with no problem.
Good luck!
Old 08-04-2017, 04:48 PM
  Pelican Parts Technical Article Directory    Reply With Quote #14 (permalink)
Thank you 88 carrera. Looks super clean. Im going back to the local dealer and return the bracket, spacers, and plastic bumper mounts and order the same set up you have. Thanks again for your time to reply
Old 08-04-2017, 06:05 PM
  Pelican Parts Technical Article Directory    Reply With Quote #15 (permalink)
I hate front license plates. My state (OHIO) requires it as well, but i've been riding dirty without one on my 996tt
Old 08-10-2017, 12:40 PM
  Pelican Parts Technical Article Directory    Reply With Quote #16 (permalink)
Ya. I would do that also, but i dont want the hassle of being stopped. Especially if ive hadacouple pops!!!!
Old 08-10-2017, 04:10 PM
  Pelican Parts Technical Article Directory    Reply With Quote #17 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
