Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 996/997/991 Forum
rufrob's Avatar
Question Front suspension clunk
Hello. I read many treads but can't seem to be a definitive answer.
I am having and clunking noise from the front left suspension. My 2002 996 turbo has only 27000km or about 15,000miles. I have checked the suspension many times all the mentioned places, drop links, ball joints, tie rods. The clunking noise is now being felt in the brake pedal.
It sounds like a loose shock or top bearing.
I would rather not remove the front strut. Is there anything else I can check or an easier way to check for this noise?
Steering wheel feels tight but it definitely doesn't feel as direct as my 930. Its a bit squirrely under hard braking, but I attribute that to new rear tyres and rutted roads.
Any advice would be greatly appreciated.
Never give up
Old 08-04-2017, 03:21 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Jeff Alton's Avatar
For the braking issue, have the alignment checked and ensure the rear toe setting is on the high end of the factory spec for road use.
Check sway bar bushings on the front for the clunk.
jeff@turn3autosport.com
997 S 4.0, Cayman S 3.8, Boxster 2.7, Boxster S race car, 996, 955 Cayenne TT, 958 Cayenne TT
Old 08-04-2017, 07:14 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
rufrob's Avatar
Already checked the sway bar bushings. I should get and alignment check but I want to install lowering springs first.
Never give up
Old 08-04-2017, 07:16 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
PCA7GGR's Avatar
Check the bolts that attach the calipers to the strut.
Sergio
PCA - 35yrs / Ex-RGruppe #197
'04 GT3 Halloween/SF Giants car
'11 E550 Coupe (Königstiger)
Old 08-04-2017, 07:27 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
rufrob's Avatar
I will. But the clunking seems unrelated to braking.
Never give up
Old 08-04-2017, 08:26 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
rufrob's Avatar
I lifted the car took off the front wheels and underbody covers. Nothing loose or out of place. Guess it must be the strut mounts. From what I've read they deteriorate with age in as much due to use.
Never give up
Old 08-06-2017, 03:45 PM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Recreational Mechanic
Nickshu's Avatar
The "tuning fork" suspension arm is the most common clunk source. They are considered a regular wear item and wear out after awhile. On mine I found the clunk was due to a stripped bolt, the forward most front suspension plate bolt that goes into the body. Fixed with a helicoil, all good since.
Current fun: 2003 996 Carrera 2 - Midnight blue / 1964 Corvair Spyder turbo convertible
Past fun: 1982 911SC Coupe (SOLD to a fellow Pelican) / 2005 Lotus Elise Supercharged (SOLD)
Current Dailys: 2018 Volvo XC90 T8 R-Design / 2015 Volvo S60 Polestar
"Straight roads are for fast cars, turns are for fast drivers" -Colin McRae
Old 08-07-2017, 04:03 AM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
dporto's Avatar
The "Tuning Fork" (lower control arm) is super easy to check, so start there. If it turns out not to be the problem, the Top mount would be next on my list (Mine were both shot). Unfortunately, they're much more difficult to check/replace. The good news is that once you do them you'll be so happy! I went with (Tarett) mono balls and am very happy I did (in addition to Bildtein B8's, H&R sport springs, H&R adjustable sways & drop-links). Good luck
Old 08-09-2017, 10:53 AM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
I have the same problem let me know the outcome.
Old 08-09-2017, 02:38 PM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
so which is it? related or unrelated to braking?
Maybe the rubber insert in the lower control arm is deteriorated, caster arm is clunking when you brake
Sure you're not referring to the caster arm? I know it's all semanitcs but it can get confusing. From what I've seen the lower control arm is the "wishbone"
1999 Porsche 996, GT3 aerokit
1974 Porsche 914 (under restoration)
2006 BMW X5 4.4
Old 08-20-2017, 06:26 PM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
rufrob's Avatar
Not related to braking means the noise is not affected by braking. Brakes applied or not the noise occurs. The noise is also a vibration which can be felt on the brake pedal, more on the arm than on the pad, and on the steering column not wheel.
It's being transmitted around the firewall. I haven't had a chance to check the fork. I'll do it this week.
Never give up
Old 08-20-2017, 07:08 PM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
rufrob's Avatar
Finally got under the car. The fork bolts are tight and no play in the ball joints. I noticed the noise is less when the car is hot. The noise is more noticeable when the car is cold and at first drive. So I did find the left side coolant line touching a hanger around the middle of the car. I stuck a rubber strip into it. No change. So that's not it. I tugged on the coil springs and found the left has more play than the right. So I'll bite the bullet and get the strut mount, when I have the money. I want to install lowering springs and get an alignment at the same time so ¥¥¥¥¥¥¥&
Never give up
Old 08-28-2017, 01:07 PM
  Pelican Parts Technical Article Directory    Reply With Quote #12 (permalink)
rufrob's Avatar
Finally did the strut bearing, bump stops and boots. Noise is gone. I thought I had to remove the strut. But it wasn’t necessary. I removed the top nut, unwound the coil spring, pulled the piston down and swapped the parts. Total of less than 1 hour. Impact gun is necessary to achieve this time. Now it’s quiet and handing improved. I adjust the camber a bit and now it tracks nicely. I resisted the temptation to cut the spring.
Never give up
Old 10-20-2017, 04:57 PM
  Pelican Parts Technical Article Directory    Reply With Quote #13 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
