Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 996/997/991 Forum
j911brick's Avatar
No start on 99 996.
Engine turns over fine. No codes on the durametric. Changed crank sensor with new one. Wont even hit on ether. Just doesnt fire up. Car just died going down the road. Any thoughts?
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 08-17-2017, 08:49 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
j911brick's Avatar
OK, so it WILL fire on ether. Other than the fuel pump, which is only 2 months old, any other ideas? Fuse is good.
james
Old 08-17-2017, 09:28 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
NYC
I assume you can here the fuel pump running when you first turn you ignition key. I have seen these pumps installed in the wrong position. They will detach from its base on the bottom of the fuel tank causing the pump to lean on its side so if you only have a 1/4 tank of fuel or less the vehicle will not start. Check your fuel filter? Fuel gauge reading properly? I am sure you did some of these checks.
Old 08-23-2017, 07:43 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
j911brick's Avatar
Thanks for the reply. Turned out it was a faulty fuel gauge so it was out of gas.
james
Old 08-23-2017, 09:03 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
