Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 996/997/991 Forum
2003 Porsche Enthusiast
vljbbeach's Avatar
Fault Codes P0442, P0445
My duremetric states fault codes are Leaks detected in Fuel system. Is it recovery vapor system? If so where do I start testing. Gas cap seal is good. Having trouble filling my gas tank to the top. Car will stall every now and again. Throwing fault codes. Clean throttle body and Maf sensor. No vacuum sound when opening gas cap. Seal is new. Can I test bleeder valves and how?
Vin
Old 08-23-2017, 06:30 AM
JFP in PA's Avatar
Vin
You didn't give the year and model, which is always helpful in these things, but I will take a shot at it: P0442 is the code for a small leak in the fuel ventilation system; P0445 is for the failure of your EVAP system purge valve, which is probably the source of the leak.
Accrochez-vous bien de vos rÍves..........."
Old 08-23-2017, 07:44 AM
vljbbeach's Avatar
P0442, p0445
Thank you for the reply. 2003 Porsche 911 Carrera 4 Cab. with a 996 engine.
P code info is greatly appreciated. Will look into replacing this.
You where very helpful.
I hope this resolves my issue.
Vin
Old 08-24-2017, 07:43 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
