Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 996/997/991 Forum
Drain Plug Leak After Oil Change - Do Over?
So I was unimpressed to find the K&N premium oil filter I bought online didn't come with a new aluminum crush washer.
I flipped the old one over, and reused it. Now have a leak from oil drain plug, dripping same day onto garage floor.
I had torque plug to recommended value, and have since tightened 1/4-1/2 turn more to see if I could get leak to stop. No luck, still leaking.
Thought - am I condemned to draining all of the new oil and fitting another drain washer? Anyone vote for further tightening the plug to see if I can get leak to stop? If I do drain, thoughts on putting the drained oil back in motor?
Bruce
2002 C4S 105kmiles
2002 C4S 105kmiles
Boston MA
Old 08-26-2017, 12:30 PM
Banned from Boulder
Jrboulder's Avatar
No way would I go any tighter.
1976 Porsche 912E Grand Prix White
2013 BMW 328i Sport Line 6MT
Old 08-26-2017, 01:06 PM
Good advice. Will drain oil into clean container and start again.
2002 C4S 105kmiles
Boston MA
Old 08-26-2017, 01:07 PM
Functionista
manbridge 74's Avatar
If one is forced to use a crush washer again, and by forced I mean no access at all like at the track or in the boonies, it is important that:
-both surfaces are clean
- washer is not oval
- washer is totally flat even if you have to hand mill it on flat surface using 400 grit or so
- that old drain plug is not cracked around area just wider than 8mm opening
Best to keep a few on hand along with extra aluminum drain plug
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 08-26-2017, 02:22 PM
Don't drain the oil. Slide your thumb over the hole as you remove the drain plug. Change the washer with your other hand, then replace the plug.
Any loss should be minimal.
Sent from my Nexus 5 using Tapatalk
Old 08-26-2017, 06:17 PM
Best solution is buy a new LN magnetic drain plug & crush washer from Pelican and & swap plugs over a drain pan. Should be able to do this & spill less than a quart.
Old 08-27-2017, 09:21 AM
Anyone ever use a Fumoto Oil valve on these cars? I typically put them on all of my cars for simplifying the LOF process. Ground clearance has never been an issue for me. However I'm in the market for a 996tt and would consider this if appropriate.... It eliminates the crush washer conundrum I always found myself dealing with.
(yeah 1st post!!)
Old 09-20-2017, 11:21 AM
JFP in PA's Avatar
(yeah 1st post!!)
We have had to repair and clean up the mess after customers tried one of these and then discovered how really low to the ground the sump is; I would not recommend anything that sticks out.
A 996 turbo car uses a dry sump system and has two separate oil drains as well.
Accrochez-vous bien de vos rÍves..........."
Old 09-20-2017, 12:27 PM
Interesting & good to know. I'm learning more about these cars everyday. Thank you!
Old 09-20-2017, 01:04 PM
FPB111's Avatar
Actually 4 if you count the turbo drains. That equals 4 washers, 3 different types of washer.
2004 996 Turbo CAB X50
2003 996 cab 6 speed Sold
1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold
DE instructor since 1985
Frank
Old 09-21-2017, 06:55 AM
How much comes out of those turbos?
Porsche 2005 GT3, 2006 997S
Exotic: Ferrari F355 Spider, 328 GTSi
Collectibles: 95 F355 Berlineta, 348TB Challenge
Disposable Car: BMW 530xiT, Audi A3S
Old 09-21-2017, 07:47 AM
JFP in PA's Avatar
Very small amount, perhaps a cup.
Old 09-21-2017, 08:35 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
