Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 996/997/991 Forum
Administrator
Dmitry at Pelican Parts's Avatar
How to Replace Porsche Brake Pads DIY Video (for Cayman, Boxster, 997 Carrera)
Replacing your brake pads is one of the easiest jobs to perform if you know the steps. In general, you should inspect your brake pads about every 10,000 miles, and replace them if the material lining of the pad is worn down enough to trigger the pad replacement sensor. In this video, we'll walk you through brake pad replacement on a Porsche Cayman that takes you through every step of the process so that you’ll have the confidence to do it yourself.
This particular video can be used for 2006-2012 Porsche Caymans, 2005-2012 Porsche Boxsters and 2005-2012 Porsche 997 Carreras.
For more how to DIY content, including tutorials, check out and subscribe to our YouTube Channel here!
Old 08-31-2017, 01:51 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
