Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 996/997/991 Forum
PMW PMW is offline
99 996 brakes slowly lock up.
Went to the track car ran fine unloaded it went for a drive and with in a 15 to 20 min front brakes would slowly lock up.
I pulled the brake booster valve the car would roll again.
Change booster and master still the same.
I pulled the and fuse, same.
I then tried to adjust the push rod
To soften thinking not retracing back far enough, same.
Car has steelbraded brake lines the one that are plastic coated and are in good shape.
Any ideas?
Old 09-05-2017, 12:18 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Had same problem with 2001 996 turbo ended up replacing abs pump/valve unit that fixed
The problem was big $$$ could not find used one
Old 09-21-2017, 04:22 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Don Plumley's Avatar
Moving to 996 forum
Don Plumley
96 993 Track Hippo | Spinning Hippo Racing
Old 10-08-2017, 01:54 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright 2016 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
