Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 996/997/991 Forum
Unhappy no crank, no start
Please help. 1999 c2, 74 k. Ran well till immobilizer got wet. Replaced with a good used one. Sent ecu, immobilizer and key to ECU Doctor. Re programmed all, and new key fob. Returned with note all good, plug and play, not so much, no crank/no start. New battery, DME, Bosch rebuilt starter, ignition switch, fuel pump relay, all fuses good, engine ground good. In the key start position, 12.7 volts at pin# 30 perfect continuity at pin # 87, no crank. Jumper pins 30 to 87 key to start position, bingo, cranks normally. OK, needs a new starter relay. Installed new relay, no crank? Maybe defective new relay? Installed 2d new relay, still no crank/no start. Everything else electrical works ok, wiring great condition. Need help.
William Mikesel
Old 10-17-2017, 07:01 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
FPB111's Avatar
Did you check the clutch pedal interlock switch? Unplug the wires and make a jumper to connect the two female spade connectors.
2004 996 Turbo CAB X50
2003 996 cab 6 speed Sold
1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold
DE instructor since 1985
Frank
Old 10-17-2017, 05:10 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Thanks, sorry I forgot to note tiptronic, neutral start switch is good.
Old 10-18-2017, 05:04 AM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Tags
no craank/no start
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
