Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 996/997/991 Forum
2002-911/996 Auto Trans - Ignition key will not turn..
After inserting my ignition key I cannot turn it to start the car. (this problem has occurred "intermittently" before and I was able to clear it by jerking the steering wheel one way, and then the other allowing the ignition key to then turn) The steering wheel is now locked up, and jerking the wheel to the left and right does not work. Please advise what my next steps should be in correcting/isolating this problem. (I have two ignition keys and they both behave in the same manner)
Just want to check to see if I was missing anything that might be obvious before I start ripping and tearing to replace anything.
Please advise.....
Old 01-10-2018, 09:47 AM
Jeff Alton's Avatar
Need to replace the switch. may just be the electrical portion which is cheap and easy.
Cheers
jeff@turn3autosport.com
997 S 4.0, Cayman S 3.8, Boxster 2.7, Boxster S race car, 996, 955 Cayenne TT, 958 Cayenne TT
Old 01-13-2018, 07:59 PM
Hi Jeff....that is on my list but would that cause the ignition switch to not turn at all? Seems like a tumbler issue me....Larry
Old 01-14-2018, 08:23 AM
FPB111's Avatar
Yes pull the electrical part off of the back and then see if the key turns.
2004 996 Turbo CAB X50
2003 996 cab 6 speed Sold
1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold
DE instructor since 1985
Frank
Old 02-03-2018, 08:48 AM
